[C9C1] Strategy Files
C9C1 calibration can be modified and configured to operate all EFI-SD2x ECUs in 4 cylinder, 6 cylinder and 8 cylinder configurations.
Locked
EFI-SD2x hardware 80s/90s Speed Density trucks
used originally on the late 80s bronco with 6 cylinder and A4LD auto trans.
Can be used on v8s and manual transmissions.
C9C1_240904.xdf
6 cyl / 8 cyl manual trans or A4LD. No E4OD support.
(173.66 KiB) Downloaded 1076 times
C9C1_V8_302_19s.bin
19lb injectors, V8 302 w/ manual trans
(56 KiB) Downloaded 2078 times
C9C1_stock.bin
stock 6cyl 2.9L w/ A4Ld automatic 86-90 bronco
(56 KiB) Downloaded 1823 times
DECIPHA_210620.adx
C9C1 selected
(384.07 KiB) Downloaded 2131 times
Re: [C9C1] Strategy Files
adx added
6 cyl and 8 cyl bins added
figured out yesterday the opclt scalars are actually the ectstabl scalars
will be posting new xdf sometime next month
updated xdf with spark retard multipliers and table added
Locked
