EL falcon 6 cyl eec running 5.0 v8
Posted: 2022 Aug 09, 07:35
Hello to all.
thanks to Decipher for the great tutorials / and information on his site and forum also thanks to TI Performance for there library of info.
My project started by installing a 5.0 efi Windsor v8 and 4 speed electronic auto into my XH falcon ute and the conversion donor car was a fairlane with a 6DHD eec-v 104 pin that i made a wiring adapter to connect them and tune with Sailorbob"s Def .
The electronic auto has a separate tcu to control it but there hasn't been a way of tuning the trans control unit so i started the process of disassembly after i was reading theA1C and RZASA are able to run 4 cyl 6 cyl or v8 .
Australian EF 6 cyl Falcon 4.0L eec-v 60 pin SD that has batch fire for injectors and 2 driver banks similar to A1C and runs our electronic BTR 4 speed auto .
(6DBB and HWAD3 and ETV-513 hardware for auto)
(have also run it on a 6TAA and HWAD2 ETV-512 hardware for manual)
PART 1. I have found the scalers that i think change the injector number / banks / number of pips and have it running with a original eec 6 cyl body and engine loom that i added a additional injector to each bank .
(no major cutting and splicing required just lengthen the TFI wires and ECT wires on body loom)
PART 2. I will make a base tune and post it up when i get the VE table sorted on the dyno if any one wants to do similar conversion.
PART 3. TODO make up a patch / find the pid"s to datalog .....
