03 Cobra Swap
Posted: 2022 Aug 08, 16:25
by Bababui
Does anyone know the best way to wire a 03 cobra engine into 89 mustang ?
I do not want to use Ron Francis wiring.
Thanks for any help
Re: 03 Cobra Swap
Posted: 2022 Aug 08, 16:34
get an 01-03 f150 wiring harness
snatch an 03/04 luxury sedan ecu
go wire by wire and simplify it. When done you should have 3 wires. Ground, battery 12v constant power and ignition 12v.
details-
http://www.efidynotuning.com/efiswap.htm
Re: 03 Cobra Swap
Posted: 2022 Aug 08, 20:40
by Bababui
I already have the ecu from the engine. All the harnesses that came
With it as well.
Should I still get the f150 harness or use the one that came with the donor 03 car?
Re: 03 Cobra Swap
Posted: 2022 Aug 08, 21:21
use the donor one
just go through and clean it up
pin out is on the homepage under reference
