Page 3 of 9
Posted: 2022 Aug 17, 11:49
Use the maf ad counts givwn in the histogram which gives the maf the most resolution. Then just leave the histogram up drive and apply the correction tunerpro gives you.
/done
you dont have to calculate anything it tells you the error
Posted: 2022 Aug 22, 22:30
by entity-unknown
I believe I understand what you were saying now bout how I won't be able to tune the MAF table the way I had it configured. The AD counts in the table aren't "friendly numbers/increments" and also don't translate well to the logs. If the log values for AD counts in the histogram are based on say 200, 225, 250, 275,etc. but the MAF transfer AD count table is say 212, 241, 268, etc. then it's not easy to tune since things don't evenly line up.
Changing the MAF transfer table's AD counts to increment equally as the histogram log table so both are 200, 225, 250, 275 etc. means the reporting AD count range is equal to the config range. Almost like having table X in Fahrenheit and table Y in Celsius. Just stick with one or the other so no guess work ;)
Here is the old which was copied from the 80mm Lightning MAF transfer table (original table in Volts, this table was the resulting conversion in TunerPro for AD Counts) vs. the new AD Counts column I somewhat mimiced from the log history table. I tried to give myself the most resolution in the AD count region I've seen the most which is 200 to 700+ish.
New Old
0 0
100 112
150 127
200 147
225 171
250 195
275 223
300 254
325 283
350 309
375 342
400 371
425 401
450 437
475 473
500 522
525 575
550 628
575 678
600 723
625 773
650 831
675 885
700 936
725 972
750 996
800 1019
900 1034
1023 1038
3200 3200
Posted: 2022 Aug 22, 22:44
you only need to go up to 1024 you dont need 3200 in GUFX since the code wont allow it
might as well ads 850 ad counts
Posted: 2022 Aug 22, 23:02
by entity-unknown
I tried 9999 and it converted it to 3200. I figure this compensates for a critical failure like setting 16+V because I have seen batteries over charge to 16.8v before due to a bad regulator/rectifier.
If you are confident on that hard limit at the code level, then I'll gladly add 1 extra point of resolution.
I know you read these and your time is valuable so I'll go with no reply means,
Yes, do it ;)
Posted: 2022 Aug 23, 06:52
if your using the a9l2 then yes as i wrote the code myself.
Posted: 2022 Aug 23, 17:20
by entity-unknown
It shall be done :)
Posted: 2022 Aug 24, 16:14
by entity-unknown
After a couple decades of log/trend/performance analysis in the IT Security space, yep, no F'in way was I gettin this tune done right without having the simple/logical MAF transfer table column to adjust based on the log history :D
Dialing this in just got a hell of a lot easier. Before I can see it would've been a never ending fight. Now I'm riding very close to 1.00 in all AD count ranges I've hit. Good call!
I extended your definition file for the N_IMAF_IEGOs (I know I can use IEGO1 since I only have 1 O2 sensor but meh) to 15 columns up to 4500 RPMs which gave some more helpful data for me. I'm on 35" tires and 5.13 gears so over 3K RPM is not unusual which was where the cut off in the definitions is. 2K is like my average cruising RPM with the tires/gearing. Not complaining either, just sharing ;)
Posted: 2023 Jun 20, 14:05
by entity-unknown
I've gotten a lot of progress especially with changing the History Table Rows to match the AD Counts I have in the MAF Transfer table. My MAF transfer based on AD Counts is below. I spaced the rows values by 25 for the areas that had the most activity, with broader strokes elsewhere within the 30 row limit with 0 and 1024 required for max/min, then matched the History Tables so I have a 1:1 comparison from log to config as suggested.
I've got things dialed in nicely now and I've had some questions about what I observe in the "Fuel_Err_1+2_Filtered" (Z object) with AD Counts as Rows Y and RPMs as Columns X (based off N_IMAF_IEGOs). I'm attaching my XDL Log file (flat street to uphill to downhill run) and Definition File as well. My History Table is "Bonnie - MAF AD TuningZ".
The AD Count values in the same row decrease as the RPMs increase. Examples (not from log file attached. These are from just a pure flat street run):
AD Count 900RPM 1200RPM 1500RPM 1800RPM 2100RPM
300 1.075 1.021 1.003 0.923 0.919 Average Of All Rows: 0.9882
325 1.069 1.045 0.980 0.927 0.925 Average Of All Rows: 0.9892
If I take the average values across the rows, then I'm pretty much spot on, just a tad rich. But that's per RPM range. So example for 300 AD Counts... If I spent 98% of my time in the 2100RPM range, I'm running .919 average (fairly rich) then the other 2% of the time in the other RPM ranges, say 1500RPMs, then I'm at 1.003 2% of the time (damn near spot on).
I've found the Parameters, "Y - Adapt Load Scaling - FN021" & "SP**FN1036B - DECIPHA Inferred Load (FN1358)"
These seem to have some relation to the differences across the single rows relative to RPMs which to some effect is relative to Load.
The scaling values for those Parameters seem to kind of correlate to the "downslope"? of AD count values across the RPMs that I observe.
Is that true? Regardless, can you explain these fields and maybe how you'd consider tuning them or at least consider them in your tuning calculations? And if I'm wrong, please point me to a better Parameter/Function? :)
Thank You!
AD Count Resolution MAF Transfer Table w/ Values for my build:
0 26.8
100 26.8
150 32.2
200 37.2
225 45.4
250 53.1
275 65.0
300 77.7
325 89.5
350 104.5
375 119.9
400 134.0
425 147.6
450 159.4
475 176.7
500 198.0
525 221.7
550 246.2
575 270.3
600 298.0
625 327.0
650 358.8
675 393.4
700 436.0
725 481.0
750 526.0
800 624.1
850 734.5
900 881.2
1024 1343.6
Posted: 2023 Jun 20, 15:19
i just read your post and im not understanding what your asking
Posted: 2023 Jun 25, 09:53
by entity-unknown
I replaced my MAF sensor and the stats were more consistent so I'll mess with this some more.
My main question is what are the parameters "Y - Adapt Load Scaling - FN021" & "SP**FN1036B - DECIPHA Inferred Load (FN1358)" used for and how do they factor in the calculations the ECM does? Also what does the blue/red color mean in Inferred Load?
