desmaf and isdc?
Posted: 2022 Jun 27, 23:36
I've not been keeping up to date and have only just learned about new method for dialing in idle air in A9L2:
What isc multiplier table do I need to enter values into? Is it FN1861 ISDC Base Targe Neutral/Park (ISC Multiplier) or one of the other variations that are listed?
Any other more explicit tips about how I enter the isdc value at (given run time/temp)?
What role does Desmaf play?
Sean
I have a new dashboard item (DESMAF_PID_N) but there are zeros showing there.The new file has dashpot and the isc multiplier simplified even further to make dialing in the idle air iscdc extremely simple. How simple? Stupid simple!!!
iscdc = isc multiplier table value
dashpot = +iscdc adder
ipsibr (desmaf_pid_n) = +iscdc adder
The logged dashpot value will be the iscdc added to the base iscdc (the base iscdc is the value in the isc multplier table).
The logged ipsibr correction is the ISCDC correction for adjusting the isc multiplier table. I.E. (ISCDC = ISC Multiplier table + ipsisbr)
An ipsibr value of 0.10 means its adding .10 to the iscdc.
DASHPOT gain value of 0.001 comes out to (TPREL * 0.001) so tprel is the iscdc adder for dashpot.
EX: 750 tprel (wot) * 0.001 == 0.75
at wot, the dashpot value will be 0.75 therefore dashpot is adding 0.75 duty cycle to the isc.
E"XTREMELY SIMPLE. This will make dialing in the base iscdc in the isc multiplier table about as easy as possible. You simply look at the iscdc at a given cell and plug that value in and done.
Sean
