Decipha, since I don't fully understand, how close to correct should I expect your T4M2, FN1036A table values to be for my 95 Cobra, with bolt ons, PRLDSW set to 0, and FN035 dialed in?
When setting the T4M0 PRLDSW switch to 0 instead of 2, does that make the stock T4M0, FN1036A table values incorrect?
T4M2 FN1036A
- Vehicle Information: 95 Cobra
Re: T4M2 FN1036A
not very
prldsw is irrelevant
fn035 has no bearing either
nope. Failed load only had one correct value
the totldst in histogram automatically givws you the corrections
Re: T4M2 FN1036A
not very
Re: T4M2 FN1036A
Thanks, I'm just learning TunerPro logging setup. So, is this what I need to do in this case?......... set up my RPM columns and TP-REL rows, then log N_TP_TOTLDSTerr in TunerPro?
Re: T4M2 FN1036A
its already setup you just simply apply the correction it gives you
