PTO?
Posted: 2022 Jun 25, 10:43
by Gary Lewis
I'm wondering what the PTO function does. I've tried to search the forum for info on it, but the search function requires 5 characters and "PTO" is only 3 and I've not figured a way around that.
From what I've read, which is very minimal, the PTO function appears to turn off monitoring of certain things, like the cats, purge system, EGR, etc. Is that right?
What I'd like to do is to cause the idle RPM to go up X RPM when I flip a switch so my alternator will provide more juice for things like running the winch or the air compressor. I was hoping that the PTO function would do that, but if it does I haven't found it.
Any suggestions?
Oh yes, I still don't seem to be getting notifications for responses. What am I missing?
Re: PTO?
Posted: 2022 Jun 25, 12:59
thats basically what its for
power take off is for larger trucks who use the engine to power hydraulics and other engine driven accessories
no idea
Re: PTO?
Posted: 2022 Jun 25, 13:34
by Gary Lewis
Ok, if that's all PTO does then it doesn't help me.
My truck has both a winch and an inverter running a 2 HP 110v air compressor, so there's lots of power usage and I could use a stepped-up idle when running those. So I'm exploring the idle air adder for low voltage. We shall see.
Re: PTO?
Posted: 2022 Jun 25, 13:58
what your wanting cant be done with BE
youd need to become a premium member to upgrade to tunerpro
Re: PTO?
Posted: 2022 Jun 30, 10:20
by Gary Lewis
Sorry, I missed your post as I'm not getting notified.
I almost have the stepped up idle working via BE. ALMOST. BE has a table called Low Voltage Idle Air Adder with seconds in the Y axis and RPM adder in the X. I changed that from all 0's to a ramp up starting at 1 second and going up to 255. And then I changed Charging System Lowest Voltage to Indicate Bad to 12.0V and Charging System Lowest Voltage to Indicate Good to 13.0. Sure enough, when the voltage got down to 12.0 the desired idle RPM came up by the requested 96 RPM for the first second. But on the 2nd second it only went up by 52 when I called for 104. And at that point it quit increasing. And, when the voltage came back above 13.0 the desired idle RPM didn't come back down until I turned the engine off and restarted.
So I got part of what I was asking for it to do, but not all.
But I'm surprised that BE can't do that and TunerPro can. What is it that TunerPro can do that BE can't?
Re: PTO?
Posted: 2022 Jun 30, 13:08
allow custom code patches
Re: PTO?
Posted: 2022 Jul 01, 09:59
by Gary Lewis
Oh. Ok, thanks.
