EGR spark modifiers and fuel pump control
Posted: 2022 Jun 07, 00:19
Rounding out my first engine up build with heads I ported and trying to see if you can include some of the more granular EGR and fuel pump controls that were available on your previous iterations of the craj0 def and bin.
Ive significantly changed my CR from stock and the stock EGR spark modifiers wont work for me anymore Im afraid, getting some pinging even with neutered timing in fn2200 at PT with EGR flowing.
Was also hoping you could include the high speed fuel pump control that was also previously included. Want to deactivate the low speed section to open up my fuel pump choices. The pre 97 pumps cog when not fed enough voltage al la the 2 speed pump control on the 98 gt's.
