FN2300 MBT table adjustment
Posted: 2022 May 26, 16:41
My spark modifiers are null for AFR / Lambda. Other parameters are set in such a way that I should only be getting the timing commanded in the borderline table.
Since I command 3 to 6 more degrees timing than stock from idle to max RPM, is there performance to be gained by adjusting FN2300 closer to, or matching the "known good" timing values commanded in my borderline table (FN2200)? If so, what is your preferred process?
On the other hand, is there any reason to NOT be adjusting FN2300 (MBT table) at all?
Thanks!
Thanks!
