Looking for EFI-SD42 board images and BIN file
Posted: 2022 May 09, 18:46
by wwhite
Hi,
Looking for EFI-SD42 circuit board images front and back if possible please.
Also, looking for binaries for JOY0 or ZAK0 or similar for EFI-SD42.
I believe these boards are for 5.0l manuals, with power steering pressure switch input.
Why?
I'm doing a fare amount of hacking on SD boards and this is just another thing to add.
I am reverse engineering so I can fully understand that I/O pin on the CPU, as well as follow the traces on the circuit board to follow what EEC-IV pin to use.
I will soon have 3-4 extra input/outputs that I can use for whatever I want.
Example: trip minder output, A/F input, maybe VGT.
Re: Looking for EFI-SD42 board images and BIN file
Posted: 2023 Apr 28, 23:56
by dnschneid
I have a SD42/JOY0 if you're still interested (looks like it's been a year)
Posted: 2023 Apr 29, 00:11
by wwhite
Ah, yes, had to read my own post to remember why.
I’m interested in the power steering switch circuitry, and the code with it.
So, yes, still interested.
Posted: 2023 Apr 29, 00:29
by dnschneid
Attached the bin.
My only photos right now are angled shots of the caps that I'll be replacing when I take the ECU out to lock in the tune. I've attached them in case they happen to be helpful, but I'll take proper top/bottom photos when I have the module out next.
Posted: 2023 Apr 29, 12:09
by wwhite
Thank you!
Posted: 2023 Aug 29, 22:18
by dnschneid
So I just discovered that none of the '95 F150s were actually wired for a power steering pressure switch (according to the EVTM). I guess my 5L/M5OD config simply came with the legacy ECU.
Posted: 2023 Aug 30, 08:54
attached ZAK0
I found it laying around and didn't read it out directly so I don't know if its correct or accurate or unmodified but should be stock.
Posted: 2023 Aug 30, 15:05
by wwhite
Cool. Thank you
Posted: 2023 Sep 01, 01:23
by wwhite
So, what I have found with both JOY0 and ZAK0, is that the PSPS is set to 0.
I have yet to find a stock bin where it is set to 1.
Maybe I have the wrong scalar.
d1f8: 01 byte 1 KIHP
d1f9: 00 byte 0
d1fa: 00 byte 0 PSPS
Posted: 2023 Nov 05, 00:28
by Jamie from oz
In some of the Aussie SD ones I am working on have "hardware present set to 0" and it appears to be compared to 1 as being not present.
I will post a example when I have computer on.
I might also be looking at it incorrectly....
