05 slot style MAF 2.75" blow-thru
034v
Unread post by 034v »
Ford sensor here.
P3M ECU (bastard mix CBAZA/GSALI)
Need a MAF xFer for it in a 2.75" housing.
Tried the one on the site, but 77mm is not matching scaled or non scaled.. Tried several other xFers as well.
42# greens at 39.15, stock h/c/i.
Is there a cheat sheet available or mathematical formula I'm missing?
Thanks for everything
Re: 05 slot style MAF 2.75" blow-thru
take the oem slot 3" transfer off the homepage and simply multiply it by the fuel error and it should be done.
034v
perfect thanks
