[CVAF1] Strategy Files
Posted: 2021 Mar 02, 13:45
99-01 mustang v8 cobra/gt
can be used on cobra and v6 with minor adjustments
MUST READ THIS- ALTHOUGH ITS OUTDATED ITS STILL RELEVANT.
http://efidynotuning.com/eecv.htm
Note: cvba2 and cvaf1 are offset by 2 bytes
**One out of a hundred 2001.25 to 2001.5 quarter year ecu's are not supported.
This only applies to 1 out of 100 original RVAF1 or RVAFA strategy ecu's that do not accept CVAF1 nor FBGI0 tunes.
They will run perfectly fine but throw a hego and inj 6 and inj 7 codes on fbgi0 for no reason or throw coil codes on cvaf1 which was common with earlier incompatible strats as per ford. It is not specific to any cal code and only occurs on those 2 native strategies.
99-01 Cobras can all use CVAF1 instead of RVAF3 (MSE3 and TDC0) for 01 or CVAE6/CVAE7 for 99-00 cobras.
CVAF1 preferred cals are
JRX0 - FOR MANUALS
BNQ0 - FOR AUTOMATICS
None of the stock cvaf1 cals support knock sensors originally.
other cal info
GTG3 - MANUAL, FTL2 is IDENTICAL, DVA0 IS THE PREDECESSOR TO GTG3 as well and XUG0, QOO0, DNL0, HJX3, YCW0, JKU3,JKU
Re: [CVAF1] Strategy Files
Posted: 2021 Oct 25, 08:30
new adx posted
Posted: 2022 Aug 08, 10:43
updated xdf
Posted: 2023 Nov 29, 22:55
added more notes and preferred cals
Posted: 2024 Dec 15, 16:14
posted new adx, previous was 3 years old and wasn't logging scaling percentage
Posted: 2025 Nov 08, 08:24
posted new adx and xdf. Not sure about what all has been added or changed/updated corrected fixed / created but the old xdf was from more than 3 years ago so im fairly certain alot has been improved in that time.
new adx also has the correct scaling percentage being logged now as well
Posted: 2025 Nov 08, 10:18
Posted base startup / reference tune for 99-00 gt 5spd / manual trans with boost as requested.
Tune is setup for siemens deka 80s with a custom modified sct ba-3000 maf. Has procharger at 18 lbs, otherwise stock on 93 pump.
FYI this specific car made max power and torque at 15 degrees of timing. Reference data:
489 rwhp / 463 rwtq @ 16 deg
494 rwhp / 471 rwtq @ 15 deg
465 rwhp / 464 rwtq @ 13 deg
