SBF EDIS (or CNP?)
Posted: 2022 Mar 07, 22:52
75 ford maverick bracket race car. 440" SBF, methanol injected (think of it as a carburetor but even more crude). Makes about 700hp n/a and no power adders. Shift at about 7200-ish, finish line sometimes gets up around 7800 depending on the weather. 7600 most of the time.
Looking at EDIS and using MegaJolt. I have a lot of it figured out, or "brainstormed", but a few things that people have been telling me have me concerned, to the point where I don't think I'm gonna go any further until I get some better understanding.
I have the MJ (E) box, and I have an EDIS-8 module from a Crown Vic 4.6 (96 I think). Some guys are telling me that the EDIS module won't support the RPM that my car turns. Most are telling me that 6300 is tops. Some say 25,000 tops. Who's right and who's full of it? 6300 is the stall speed of the converter for crying out loud!
Second issue and may be a non-issue. The car has a 16v battery in it, which will stay. It has 3 terminals on it, ground +12v and +16v. IT is all 16v right now. Any reason EDIS won't run on 16v? I haven't found a 12v accessory yet that doesn't work better on 16v. No alternator on this car. Running voltage stays up around 15.5v with everything on (fans, lights, ignition, etc). The charger puts out a little over 18v, and I kick the master switch off if I'm charging (always).
Thought about going with coil-near-plug but I don't have a controller for that, and would need to buy something. MegaJolt/C is a dead project and would have probably worked fine for what I'm doing. So that leaves me with MS3, right? Can MS3 run ignition only without it getting confused with not having any FI? Really all I need is a 2D ignition. Start at about 15 deg BTDC and then all in by 1000 rpm at 38, then pull 2 deg at 6000, 2 more deg by 6800. With MSD 6AL box and dist currently in the car, I can't do all that. It has really soft "HEI" springs on the mech adv, so it's cranking at 14 initial and 32 by 800, whhere it stays. It slows down at 34 deg (MPH drops way off).
