^^Subscribe to this thread so you are alerted when updates are posted^^
CBAZA is the strategy for all 94-95 mustang V8's both auto and manual as can be used as well for 94-95 F-150 V8's with clock speed ref patch.
U4P2 is the decipha modified stock 94-95 automatic v8 mustang gt tune file for premium fuel.
T4M2 is the decipha modified stock 94-95 manual v8 mustang gt tune file for premium fuel.
HUG3 is the decipha modified stock 94-95 automatic v8 F-150 tune file for premium fuel.
[CBAZA] Strategy Files
- DECIPHA_250126.adx
- cbaza already selected
- (492.13 KiB) Downloaded 865 times
- CBAZA_240216.xdf
- POSTED 25-02-23, old file was from 2021 !!! not sure how much has changed since then but im sure ALOT.
- (795.54 KiB) Downloaded 909 times
- FCL0_Stock.bin
- 94/95 GT Auto - W4H0 Low Power Mode
- (56 KiB) Downloaded 1473 times
- J4J1_Stock.bin
- 94/95 Cobra GT40 Heads/Intake 24lb Inj w/ tbird cam
- (56 KiB) Downloaded 2667 times
- L4C1_Stock.bin
- 94/95 GT Manual - No Emissions and no HEGOs Cal for non USA vehicles.
- (56 KiB) Downloaded 1470 times
- S4M1_Stock.bin
- 94/95 GT Auto AODE - W4H0 No Emissions and no HEGOs Cal for non USA vehicles. 2.73 rear gear
- (56 KiB) Downloaded 1446 times
- U4P0_Stock.bin
- 94/95 GT Auto AODE - USA (3.08) 3.27 rear gear
- (56 KiB) Downloaded 1504 times
- W4H0_Stock.bin
- 94/95 GT Auto AODE - USA 2.73 rear gear
- (56 KiB) Downloaded 1452 times
- ZA0_Stock.bin
- 95 Cobra R 351w (svt's garbage file) 3.27 rear gear
- (56 KiB) Downloaded 1507 times
- T4M0_Stock.bin
- 94/95 GT Manual - USA
- (56 KiB) Downloaded 1535 times
- FOX_SWAPPED_210514.bin
- using fox harness and cbaza swap instructions
- (56 KiB) Downloaded 1482 times
- U4P2_210514.bin
- AUTOMATIC AODE/4R70W/4R75
High Performance - (56 KiB) Downloaded 1642 times
- T4M2_210514.bin
- MANUAL TRANS
High Performance - (56 KiB) Downloaded 1719 times
Re: [CBAZA] Strategy Files
T4M2 attached.
u4p2 and updated t4m2 attached
stock tune files and notes added
posted hug3 stock tune file as well as updated xdf and adx. Nothing should be different logging wise but the older xdf and adx were from 2021 some 4 years ago. I'm sure alot has been updated/changed since then although nothing critical.
posted updated hug3 file with TCSHP corrected so TCIL functions correctly.
main differences between f150 and mustang
1 hego
tcs is led and not a bulb hptcs=2
4r70w vs aode 1st gear ratio
1 hego
major update for cbaz0 folks
cbaz0 has a different clock speed and will require enabling the clock ref patch
