Hooray
Posted: 2022 Feb 09, 11:14
by gz87ky
I had kind of given up on any MZAK0 support. Barely poke around anymore. Until today. Glad it's up and running.
Now to load my hex files into TunerPro and see what I can see.
Working on an '04 F53.
Thanks!
Re: Hooray
Posted: 2022 Feb 09, 12:54
I wouldn't hooray just yet. You have to be a premium member to do any real tuning on mzak0 as the xdf I have posted right now is pretty basic and no adx.
what all is done to the truck?
Re: Hooray
Posted: 2022 Feb 09, 17:56
by gz87ky
I tweaked some shift points years ago. Like to do a little more of that. Haven't used any of these tools. Basic is ok to start, I'll check out the premium membership.
Re: Hooray
Posted: 2022 Feb 09, 18:23
by gz87ky
So yeah, no go. Stuff all opens and loads, but values are out of whack. .bin file must not match the .xdf. I KNOW I have MZAK0. Any suggestions?
Re: Hooray
Posted: 2022 Feb 09, 19:29
did u have the key on when u read it?
post the file and ill take a look
Re: Hooray
Posted: 2022 Feb 10, 08:57
by gz87ky
It's an old binary file I flashed into the controller using other tools.
It is possible that it has (improperly) a header or something that the tools I used added or ignored.
Tim
Re: Hooray
Posted: 2022 Feb 10, 10:46
You need to read the tune file out with the qh.
What did you use you to read and write the file? What did you use to edit it?
that 217k file isn't any standard format that I'm aware of although it is an actual bin
MZAK0ZD is the WAU1 cal which is a revision of the VMA2 base cal I use for the v10s I do.
Henry simply changed the tire revs for the larger tires and kicked up the gear ratio and enabled vehicle speed calc and was done lol.
Re: Hooray
Posted: 2022 Feb 10, 11:07
I figured out what they did.
6 bytes in the front
01 00 06 e000 20
bank 0
9 bytes
7c 00 02 00 07 c0 00 20 01
bank 1
9 bytes
10 00 02 00 07 e0 00 20 09
bank 9
0x28000
9 bytes
f5 00 02 00 07 e0 00 20 08
bank 8
end of file
11 bytes
40 00 02 00 07 00 e0 ff 08 10 00
obviously those bytes are defining sizes checksums and banks
Anyway, thats a bone stock file you have. You failed to change any shift points.
Re: Hooray
Posted: 2022 Feb 10, 12:42
by gz87ky
Correct, that is the unmodified file. I'll pm you some details, if that's OK....
Re: Hooray
Posted: 2022 Feb 10, 12:56
ok
