Franken Lightning
Posted: 2022 Feb 03, 14:30
Hi all, sorry if this ends up long, I'm new to posting. I am currently resto-modding my 79 Bronco with an 03 Lightning powertrain. I have everything together and it will run, but I do not have the correct PCM. (I'm running it with one from an N/A 5.4 to move it around during the build. I can't find a PCM anywhere except FS1 for over 3 grand! And I can't go there! (OLD GUY PRIDE)
I can't load a stock Lightning tune as the hardware code in the PCM's are different. (I have an IDS, so I can write a factory tune if I can find a PCM with the correct hardware code. (MPC-206)
1st question - does anyone know if there is a cross reference chart that shows PCM hardware codes by VIN or truck build. (The PCM I need (MPC-206) comes in a few models, I just can't find a way to look it up. There aren't a lot of lightnings left out there.
My backup (and less desirable) plan is to tune the N/A Pcm to run the lighting 5.4. I will lose some functionality doing this. Not the end of the world, but...
I was discussing it in the lightning forum in corral.net and It was suggested that I try here.
P\S I'm running a 4r100 auto and an auto T\case, all 03 ford vintage. I'm going for a certain ambiance with the build, so I have built/modified a factory harness to run everything. I'm running the factory HEC, GEM and PCM.
I am not a tuning guru, I'm actually pretty new to this world, I was a drivability\electronics specialist at a FORD dealer and I teach automotive apprenticeship at a TECH institute currently, so most of my experience is based on relatively stock and factory tools and service info.
Sorry for going on and on.
Any help would be greatly appreciated.
