2000 Ford F53 6.8L V10 Won't Start
Posted: 2022 Feb 03, 00:03
Engine will not start.
Previous owner claims after recent service he was driving and noticed the engine was overheating. Pulls over, coolant everywhere. Parks vehicle, comes back later and it will not start.
Removed and replaced all fuel.
Replaced fuel filter.
Good compression. Good fuel pressure.
Checked most COPS, all good.
IACV is open.
No damage to wiring or connectors found.
Verfied spark while cranking.
Bypassed fuel pump relay (always on)
Now here is the weird part. Pulled the starboard fuel rail, left injectors attached. (Unplugged COPS)
Turn key to on, then start. 5 pulses from the injectors, and fuel pressure drops from high 30's to mid 20's.
Injectors stop pulsing.
Let off start (key resets to run) and try to start again. No pulses. Try again, no pulses.
Turn key off and on, "start" again. 5 pulses then nothing. Reset to run, start, and nothing.
Engine does not fire at all, even with the 5 pulses.
Ohmed crank and cam sensors ~330ohms each. New sensor is 350ohms.
Inertia switch isnt tripped, not sure if that matters. Did not verify intertia switch continuity.
Lastly, tried to pull codes with Scan Gauge II, despite 'Service Engine Soon' light being on, no codes were present.
IACV is open.
