Directives file for A1C
Posted: 2022 Jan 31, 15:29
Something you are willing to share? Purely for educational purposes.
# ------------ Subroutine list----------
"Reset_All"
"Initialize"
"Background_Loop"
"Reset_RAM_ptr"
"Infinite_Loop_DEAD"
"Set_TaskList"
"SYSTEM_EQUATIONS_1"
"BRAKE_INPUT"
"Clear_Cell"
"I_External_Vector"
"DCL_Mode_Scheduler"
"DCL_DM_PermanentDeviceDisconnect"
"DCL_DM_TransmitPID"
"DCL_DM_ParameterRefByAddressOffset"
"DCL_DM_ParameterRefByName"
"DCL_DM_A-D_SensorValueSubstitution"
"DCL_DM_ClearContinuousVIPCodes"
"DCL_DM_ClearDCLErrorFlags"
"DCL_DM_TransmitDMRMap"
"DCL_DM_TransmitPIDMap"
"DCL_DM_TransmitDMR"
"DCL_DM_ProgramDataDownload"
"DCL_DM_ProgramExecution"
"DCL_DM_DisplayDCLStatusInformation"
"DCL_DM_RunningOnDemand_SelfTest"
"DCL_DM_TransmitContinuous_SelfTestCodes"
"DCL_DM_SetCommLinkBAUDRate"
"DCL_DM_TransmitBoth_PID-DMR"
"Send_HSO_Cmd"
"Reschedule_Event"
"I_HSI_0"
"Read_HSI"
"I_HSO_1"
"I_Timer_OVF"
"I_Ignore"
"I_HSO_2"
"PIP_DATA"
"SPARK_RETARD_LOGIC"
"SPOUT_CALCULATION"
"Update_HTime_pend"
"Update_HTime_prev"
"KNOCK_THRESHOLD_SENSE_(KTS)_LOGIC"
"Add_H_Beta"
"Add_H_Delta"
"EOS_KAY_CALCULATIONS"
"TRANSIENT_SPARK-COMPENSATION"
"DWELL_CALCULATION"
"FUEL_INJ_OUT_COM6"
"SET_UP_INJECTOR_OUTPUT_EDGE"
"Injector_Edge"
"Injector_Edge_Immediate_Output_Request"
"SCAP_Sensor_Edge"
"SYSEQ_MAP_COM1"
"Calculate_MAP_FREQ"
"MAP_Average_Complete"
"MAP_CALC"
"VEHICLE_SPEED_(VS)"
"VIP_THROTTLE_MODE_SET"
"KAM_Qualification_Test_Logic"
"ReInitialize_ISCKAM"
"RUN_MODE_SELECTION"
"THROTTLE_MODE_SELECTION"
"Read_AD"
"Enable_Int"
"SYSTEM_EQUATIONS_EQUA_LH"
"INPUT_ACT_COM2"
"Compute_TCSTRT"
"INPUT_TOT_COM1"
"CNVRT"
"ENGINE_SPEED_OVER_VEHICLE_SPEED_NOVS_&_BPCOR"
"INTRN_MLPS_CONV_COM1"
"INFERRED_BAROMETRIC_PRESSURE_STRATEGY"
"SPEED_DENSITY_AIR_MASS_CALCULATION"
"Compute_AMPEM_AMPEMT"
"Subtract_EM"
"AD_Substitutions"
"DCL_Handler_Dispatch"
"BIMAP_DEFINITIONS"
"DOL_PULSE_CALC_COM3"
"SUYFuncLU_4865"
"USYFuncLU_486d"
"UUYFuncLU_4870"
"UUYFuncLU_4891"
"SUWFuncLU_48db"
"SSWFuncLU_48e0" $ F sswflu 32
"USWFuncLU_48e3" $ F uswflu 32
"UUWFuncLU_48e6"
"UUWFuncLU_4907"
"UROLAV"
"ROLAV"
"ROLLING_AVERAGE_ROUTINE"
"ROLLING_AVERAGE_FILTER_ROUTINE"
"SYTabLU_49a7" $ F sytlu 38 34
"SYTabLU_49b6" $ F sytlu 38 34
"Four_Point_Interpolation" $ F uytlu 38 34
"TableInterpolation"
"Calculation_Normalized_MAP"
"Calculation_MAPWBAR"
"FUEL_OLFLG_COM7"
"TIMERS"
"FUEL_CL_LAMBSE_COM3"
"C_MULTIPLIER_LOGIC"
"LAMBSE_RESET"
"ACT_to_ECT_proportioning_factor(R36)"
"FN1360(N,MAPPA)"
"TEMP_normalization_factor_x"
"CALCULATE_PTPAMP_RF_and_RS"
"UYTabLU_5131" $ F uytlu 38 34
"FUEL_ADAPT_COM4"
"EGO_Switch_Logic"
"NEW_UPRATE_CALC"
"FUEL_IDLE_MOD_COM3"
"FUEL_KAM_ADAPT_COM3"
"FUEL_TRANS_COM5"
"FUEL_DFSO_COM2"
"FUEL_AE_COM5"
"FUEL_PUMP_COM1"
"SPARK_BASE_COM2"
"Include_in_SPK_NORM"
"ENTRY_INTO_IDLE_SPARK"
"MISCELLANEOUS_SPARK_CALCULATIONS"
"DWLBSE-DWLCOR_CALCULATION"
"SPKKNOCK_LL"
"KNOCK_HARDWARE_PRESENT"
"EGR_ENABLE_LH"
"EGR_SONIC_COM2"
"DESEM_DELOPT_CALC"
"EGRDC_CALC"
"EGR_EVR_CONTROL_COM1"
"ISC_OVERVIEW_COM3"
"DSDRPM_CALC"
"RPMERR_CALC"
"ISC_DASPOT_COM1"
"ISC_MODE_SELECT_COM1"
"ISC_IPSIBR_COM1"
"ISC_ISCDTY_COM1"
"Manifold_VACUUM"
"ISC_ISCKAM_COM1"
"DOL_LH"
"ACC_GOV_MAP_COM2"
"THERMACTOR_AIR_STRATEGY"
"CANP_COM4"
"Update_Can_Purge"
"Do_Self_Test"
"StackErrorCodes"
"Get_DiagCodes"
"Set_DiagCodes"
"EGR_SELECT_LOGIC"
"TRANS_SELECT_LOGIC"
"Check_Sensors"
"EGOTST_TMR_CONTROL"
"WARM_UP_COUNTER_LOGIC"
"KAM_CODE_ERASE_LOGIC"
"?Fault_Filter_Routine?"
"Clear_KAM"
"Clear_Kam_SelfTest"
"Set_STO"
"Reset_STO"
"GetBytes_R1a"
"EGO_TEST_TMR_CLEAR"
"Calculate_ETV_OCM_MIN"
"VO_EOTS_COM1"
"FAIL_Loop"
"VO_ROM_COM1"
"TEST_AD_SWITCHES_1"
"EXIT_THIS_TEST"
"TEST_AD_SWITCHES_2"
"GET_ADDRESS"
"VO_FPM_COM2"
"VO_OCC_COM12_Func1"
"VO_OCC_COM12_Func2"
"VO_OCC_COM12_Func4"
"VO_EPC_SOLENOID_COM1"
"Disable_No_Start"
"VO_KAMRAM_COM1"
"RAM_ERROR"
"VO_EPC_SOLENOID_COM1_624"
"VO_EPC_SOLENOID_COM1_625"
"SET_SERVICE_CODE"
"VR_RUN_INIT_COM8"
"FMEM_FAULT_PRESENT_and_INITIALATION_LOGIC"
"VR_EGO_COM1"
"VR_THERMAIR_COM2"
"AIR_UPSTREAM"
"AIR_DOWNSTREAM"
"BLOCK_F2_VR_THERMAIR_COM2"
"AM1_AM2_OFF"
"BLOCK_AA"
"DELAY_SEC"
"VR_SPARK_COM1_SAF"
"VR_SPARK_COM1_NBAR"
"VR_SPARK_COM1_213"
"DELAY_SEC(VSPTD)"
"VR_EGR_COM6"
"VR_EGR_COM6_332"
"EXIT"
"VR_LOW_ISC_COM4"
"VR_LOW_ISC_COM4_411"
"VR_GOOSE_SD_COM1"
"VR_GOOSE_SD_COM1_SET_CODE_xxx"
"VR_GOOSE_SD_COM1_G1"
"Check_PS_PB"
"VR_EGOBAR_COM1"
"HW_Check"
"POP_test"
"ZERO_MILTMR"
"VIP_EOS_IDM"
"E4OD_TRANSMISSION_CALCULATIONS"
"INTRN_E4OD_INPUT_PROCESSING_COM1"
"INTRN_E4OD_SYS_EQU_COM1"
"SPEED_RATIO_ACROSS_TORQUE_CONVERTER"
"E4OD_INPUT_PROCESSING_COM1"
"FN161x(N,LOAD)"
"SC_DESRD_GR_DETR_COM1"
"SC_GR_DS_AUTO_COM1"
"VEHICLE_SPEED_SENSOR_OK_SHIFT_LOGIC"
"VEHICLE_SPEED_SENSOR_FAILURE_SHIFT_LOGIC"
"Delay_Shift_Logic"
"MANUAL_DOWNSHIFT_DETERMINATION"
"SC_CM_GR_DETR_COM1"
"SC_CM_GR_MAN1_COM1"
"SC_CM_GR_MAN2_COM1"
"SC_CM_GR_AUTO_DWN_COM1"
"SC_TIMER_COM1"
"SC_SOL_CTL_COM1"
"SC_VALID_COM1"
"SHIFT_VERIFICATION_LOGIC_(Part_1)"
"SHIFT_VERIFICATION_LOGIC_(Part_2)"
"CCC_CST_CLTCH_CTL_COM1"
"EPC_GUIDE_COM1"
"UUWFuncLU_98a7"
"SUWFuncLU_98ae"
"EPC_TQ_IALPHA_COM4"
"EPC_DYNAMIC_COM1"
"CCC_COM1"
"CCC_FMEM_COM2"
"CCC_UNCOND_UNLCK_COM1"
"CCC_SHFT_UNLCK_COM1"
"CCC_INI_DWN_COM1"
"CCC_DWN_CNVR_CLCH_COM1"
"CCC_INI_UP_COM1"
"Calc_SR_PP_LIM"
"CCC_UP_CNVR_CLCH_COM2"
"CCC_SCHLD_LCK_UNLCK_COM1"
"CCC_WOT_LCK_UP_COM1"
"INTRN_RT_NOVS_KAM_CALC_COM1"
"CCC_VALID_COM2"
"INTRN_TCIL_REPEAT_COM1"
"EPC_OTEMP_TEST_COM2"
"TIMER_LH"
"Check_ConsoleDI"
"Check_Console"
"Console_Routine"
"KAM_VALIDATION_PROCEDURE"
