Mustang GT VMP Odin Supercharger Misfire in Cylinder 4
Posted: 2021 Nov 26, 15:42
by Denver_SVT
Hello,
What can cause Mustang Coyote Gen2 to through an error code P0304 and P0316 ?
Can a tune cause it or it's mechanical failure such as ignition coil, spark plug or internal failure in Cylinder 4?
Thanks.
Re: Mustang GT VMP Odin Supercharger Misfire in Cylinder 4
Posted: 2021 Nov 27, 12:00
if its just two cylinders then its a mechanical misfire
do a crank relearn just to be sure
Posted: 2021 Nov 27, 14:06
by Denver_SVT
We did a crank relearn and still same issue. We contacted SCT Tech and the said “it could be a checksum missing or miscalculated after the flash and they said they have seen that more than once and it’s a Ford issue.”
Posted: 2021 Nov 27, 14:34
by Denver_SVT
Is there away to try in the tune to see if it will help not detecting the misfire in Cylinder 4 ? At least to try and see.
Posted: 2021 Nov 27, 14:36
by Denver_SVT
Just to let you know that when we get the spark plug from cylinder 4 it was rich ( black color ) while the others are fine.
Posted: 2021 Dec 02, 13:39
yeah I would expect as much
