Force QH Communication Reset
Posted: 2021 Oct 30, 07:00
In some cases (especially so on EEC-V) the quarterhorse may loose configuration while still connected to the j3 port. This may happen due to writing a tune while the engine is running or even connecting the quarterhorse for the very first time.
In these cases the QH configuration can be reset in tunerpro by clicking the "Verify Emulator Ram Contents Against Current Bin" icon located 3 icons down from the upload icon. You will probably have to click this button twice as the first time you click it the QH will "default" and then the second time it will read which will probably show an error at the bottom status indicator which is normal. Simply upload the tune and all should be fine.
