mechanical idle air clarifications
Unread postby redtopracer » Sat Jun 27, 2020 11:33 pm
Ok, upon reading and rereading your idle air instructions for mechanical idle I think i could use an nudge in the right direction.
The parts on fn8000 where you say allow 0% duty cycle at 0lb/hr would that mean turn the far left column on the x axis to 0 removing the 10% clip?
And on FN1862 i divided the entire table by 6 and nowhere on it did i get 0.172 as a value in any of the cells. Am i reading this wrong?Tried this on your FBGIO tables for fn1862 to see if maybe craj0 just had bad info in it again and i didnt get 0.172 anywhere on it either. Do you mean the values of the functions will equal out to 0.172 or the it should be a value in the cells of the tables?
redtopracer
Vehicle Information: 98 mustang gt 5spd
PI engine swap
FRPP SVO intake manifold
long tubes and full exhaust
lightweight flywheel
Re: mechanical idle air clarifications
Unread postby decipha » Sun Jun 28, 2020 7:50 am
yes
the isc multiplier table fn1862 on normal tunes gives you 1.000 at warm stable idle
1.000 / 6 == 0.1667 or rounded to 0.172
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Unread postby redtopracer » Sun Jun 28, 2020 10:13 am
Can you give me a little input on that one next then as mine is kind of not a value of 1 lol Could I use the fn1862N table from one of your more developed bins for the 2v PI motor?
redtopracer
PI engine swap
Unread postby decipha » Sun Jun 28, 2020 10:19 am
it really doesnt make much of a difference what you start from since your going to change all those values anyway when you dial it in
Unread postby redtopracer » Sun Jun 28, 2020 10:34 am
So is fn1862 used to dial in just startup or is it used to dial in the entire idle on the mechanical idle mod? I think I need to reduce my iscd % at idle a little bit and I wasn't sure if I should use fn8000 or fn1862.
redtopracer
PI engine swap
Unread postby decipha » Sun Jun 28, 2020 11:06 am
fn8000 is the isc transfer. Its a set and forget thing.
All idle air is dialed in using fn1862 the isc multiplier.
Unread postby redtopracer » Sun Jun 28, 2020 3:21 pm
Success!!!!! Sort of lol
So my catch can was leaking, had cracked and was sporadically sealing up from the oil in it.
Car now idles, without hunting at 656 and in idle spark loop with no clipping back to FSB min of 10.
When the fans are off and its idling lol. It still goes crazy on the spark whenever I cruise to a stop and rpms drop below 1k or the engine fan kicks on, or the AC system is on.
Ok maybe not success but solid progress lmao.
redtopracer
PI engine swap
Return to EEC-V & SN95 Tuning
