U4P2 questions
Posted: 2021 Feb 26, 09:20
I successfully set up A9L2 for the 5.0/AOD combination in the 66 but, not being smart enough to leave "well enough" alone, I've swapped to a 4R70W.
I'm using U4P2_200705.bin and CBAZA_200702.xdf.
I have all of the engine calibration copied over from the A9L2 but I'm having a bit of trouble doing the trans calibrations. I cannot find VS21PI, VS32PI or VS43PI. All other PIDs come right up but these three bring up "No Items Found".
And a couple of quick general questions: What can I expect from OBD-1 with the Moates installed? Check Engine Lite functional? These questions never occurred to me when I set up the A9L2....everything just worked but I guess I should know what to expect...just in case.
New forum looks good and, again Michael, I can't thank you enough for the things you do.
