Lean spike help!
Lean spike help!
Unread postby beuchaw94gt » Fri May 22, 2020 4:29 pm
Ok guys so i just finished up installing my Vortech supercharger lightning mass and 42lb injectors, upgrading my rear control arms and subframe connectors. I had the supercharger done before the suspension stuff and never had it lean spike me until after(verified thru my datalogs). Now for some reason when i got WOT everything is fine until i reach 4900-5000 rpm. This is when the lean spike occurs shoot to the 13s afr. It always does it in 1st gear, sometimes second and haven't seen a spike in 3rd. Checking my datalogs everytime it lean spikes it seems to always do it during the same spot. As soon as i see it i get out of it, if i do shift they go back to normal.I do have an X-pipe installed. I don't know if its scavaging. I did notice the Hego on the Pass side drop as the drive side is unchanged(Wideband is on the pass side). I was think it my be shift related since i am running it thru an AODE but unsure. I installed an fuel pressure gauge and pressure is fine. Was thinking maybe turbulence in the intake tube. I really just need some thoughts. I will try to post my last datalog and tune, just need to read how to do it again. I am using B.E. I believe my tune is pretty conservative 11.2 fuel and 10* timing under full boost(9lbs). Let me know what you guys thoughts are.
beuchaw94gt
Vehicle Information: 1994 mustang gt auto rebuilt bottom end, trick-flow heads 170cc, tfs stage 1 cam, gt40 intake, 70mm thrpttle body42lb injectors, lightning maf, 373 gears, bbk shorty headers, x-pipe, Vortech supercharger 9lbs of boost.
Re: Lean spike help!
Unread postby beuchaw94gt » Fri May 22, 2020 4:38 pm
Tune and datalog
beuchaw94gt
Unread postby decipha » Fri May 22, 2020 5:44 pm
it sounds like u just need to dial in your maf at that maf voltage
I dont have any way to look at BE files
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Unread postby beuchaw94gt » Fri May 22, 2020 7:07 pm
Thanks for the response....Mafv 4.5....when I reach that voltage in other gears it's dead on. 3rd gear. Could there be another isssue
beuchaw94gt
Unread postby red5.0fogger » Sat May 23, 2020 6:49 am
sounds like it might be related to wheel spin. Are the tires black trackin' at that point ? Or grip is good? Or maybe accel enrichment is off since i'm sure it's blasting through the rpms at a high rate of speed in first gear. I'm just brain storming. Trying to compare things that are different in low gear vs high. The strain on engine is less so it tachs out easier/ quicker.
Premium Member
Unread postby beuchaw94gt » Sat May 23, 2020 2:47 pm
Thanks man. I pretty sure I'm getting traction. I'll have to check the accel enrichment.
beuchaw94gt
Return to EEC-V & SN95 Tuning
