RZASA p0340 CPS code
Unread postby Stock? » Fri May 22, 2020 11:58 am
First the background info:
97 Explorer 5.0
E303 cam
36lb injectors (OEM 2015 Mustang)
M-195 ECU with RZASA
Newer VR style cam position sensor (brand new duralast brand).
C4 transmission.
I started the engine for the first time this week, it takes quite a bit of cranking for it to fire. Not sure if that is related to the CPS issue or not.
I've gone through the steps from the explorer service manual - check resistance from plug to ECU, resistance between the 2 wires, shorts to ground/power. I did not find any issues.
I've swapped out the sensor for another one that came from the junk yard and swapped out the ECU.
Still getting the same error.
I believe the tune is configured for the VR style CPS.
**Edit** figured out the extended crank time, my ignition switch is dirty and cuts power to the ignition wire if I turn it to far. Starts right up now that I know that.
Could it be something in the tune causing it?
Stock?
User
Vehicle Information: 79 Ford Courier
5.0 97 Ford explorer engine
Luxury Sedan ECU/RZASA
Re: RZASA p0340 CPS code
Unread postby Stock? » Sat May 23, 2020 10:30 am
In a moment of RTFM I found the issue.
I set VCAMHP which, according to the notes, causes the p0340 and p0350 codes.
Hopefully this helps someone else
Stock?
User
Unread postby decipha » Sat May 23, 2020 11:04 am
oh yea that will cause the code hence why I put the note there.
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Return to EEC-V & SN95 Tuning
