AEM wideband sensor for EEC-IV
Posted: 2021 Aug 09, 15:34
by wwhite
I finally picked up a wideband AEM sensor.
The instructions state that position 4 (P4) can output emulated narrow band.
I know it's not ideal, and for daily driver any one done this.
Will or does this work OK for EEC-IV stock PCM?
And, on another note, I know people tie into the EGR sensor input for AEM sensor.
My bin has the following A/D channels:
3cfd: 00,08,01            struct    0, ITOT                                        # Transmission Oil temperature, counts.
3d00: 01,0e,01            struct    1, IVCAL                                       # A to D conversion of the calibration input voltage, counts.
3d03: 02,0a,01            struct    2, IIVPWR                                      # Ignition voltage, A/D counts.
3d06: 03,0c,01            struct    3, IOCC                                        # Output Circuit Check (OCC) A/D input level.
3d09: 05,44,03            struct    5, IETVOCM                                     # A to D conversion  of  the  ETV  over current  monitor  voltage, counts
3d0c: 07,1c,01            struct    7, ITP                                         # Throttle position value from A/D conversion, counts.
3d0f: 08,10,01            struct    8, IECT                                        # A/D conversion of ECT sensor, counts.
3d12: 09,12,01            struct    9, IACT                                        # A/D conversion of ACT sensor input, counts.
3d15: 0a,18,01            struct    a, INDS                                        # Input Neutral/drive switch, counts.
3d18: 0b,1a,01            struct    b, IEGO1                                       # Exhaust Gas Oxygen sensor 1
3d1b: 0c,14,01            struct    c, IEGR                                        # A/D conversion of EGR sensor input, EVP or EPT sensor, counts.
As you can see, there are 11 channels. I believe 13 can be supported.
With some clever codding, would I be able to add channel 4 or 6 to the code, and then wire up the AEM sensor to the appropriate analog input?
Any one tried that?
I am aware that a lot of code would have to be moved as there is no free space before or after the above code, and where an assembler would be nice to have.
Re: AEM wideband sensor for EEC-IV
Posted: 2021 Aug 09, 17:24
yes, nope
nope nope and nope
Posted: 2021 Aug 09, 22:11
by jsa
Yes the channels can be added to code.
If uP pins are connected to J1 pins then it is easy.
Otherwise input circuitry needs to configured like voltage in channels.
