Hello,
The Tbird was running great then started an off idle issue. When I stabbed the throttle from idle the motor would bog down pop and dye.
Found out O2 sensor harness came loose melted to long tube headers. Replaced both O2 sensors and extended harness, Reset KARMF I think, (went into BE swithed KARMF to reset hit update then back to normal hit update) Ive noticed now if feather in the throttle fast I can get by the bog pop dye but before the O2 harness melted I could go from idle to WOT no issues. Anyways Ill attach the Log. Does the clear KARMF procedure sound correct.
THanks
Nate
