refreshing my memory on injector data
Posted: 2021 Aug 03, 18:31
I'm about to ask a question(s) that I should know the answer to but I just can't find the answer in my tuning log notes.
I'd like to prepare an alternative tune that uses different (Continental) injector data for my Deka V 80 lb/hr 'shorty' injectors. I have them installed and running using the Ford Racing M-9593-LU80 (Deka IV) injector data that's provided on this site but I think the difference between what I'm using and what Continental provides may end up working better.
The Ford Racing data lists injector parameters (slope, breakpoint, offset) at base fuel pressure of 39.15 psi and then provides compensation values that are intended to be multiplied against those base parameters to match the actual FP you're using. My base FP is 55psi, so the calculation looks something like this:
base ALOSL (101.459) x 55 psi compensation factor (1.2271) = adjusted ALOSL (124.5)
base AHISL (75.157) x 55 psi compensation factor (1.1883) = adjusted AHISL (89.309)
base breakpoint (0.00002421) x 55 psi compensation factor (1.121) = adjusted breakpoint (0.00002713941)
base voltage offset table values x 55 psi compensation factor (1.1848) = adjusted voltage offset table
Can I use these same multipliers (55 psi 'compensation factors' in bold above) with the Continental base parameters? To further confuse the issue for me, Continental base injector parameters are provided at 43.5 psi FP, unlike the Ford Racing data which uses 39.15 psi FP.
Can anyone help me sort through this?
Thanks,
Sean
Thanks,
Sean
