98 Mustang Won't Crank
Unread postby lowranger96 » Mon Jan 07, 2019 9:09 am
98 Mustang originally a V6 car. Now has a turbo 2v PI engine with 98 4.6 ECU (BAI2)
I burned a chip and turned the pats off (I think).
Theft light is blinking and the car will not crank. The key, pats module, and cluster all match. I'm not really sure what's going on here. Apparently there are some codes that i can pull to maybe get an idea on where the issue is at which I will do today.
Anyone have issues or experience with this?
1996 - 2.5 CP Flattops, Billet Crower 5.2 rods, Stock head bolts, Felpro 1035, Turbo VC, P&P BV Head, 2277 Cam/spring, Custom Log/Tial MVS, HE351, FMIC, FLH2, ID1000s, HPX Blowthrough, Binary Editor, E85
lowranger96
Vehicle Information: 96 ranger 2.3 turbo
Re: 98 Mustang Won't Crank
Unread postby decipha » Mon Jan 07, 2019 12:50 pm
with pats disabled the theft light will blink since pats isn't functioning correctly to turn it off
was the car running after u burned the chip or it stopped started at that same time. If it stopped running at that same time then the chip may be corrupt. If it has been running after you disabled pats then you have other issues.
Unread postby lowranger96 » Mon Jan 07, 2019 4:20 pm
This car hasn't run in 5 years. Went to start it yesterday and here we are with no crank
lowranger96
Unread postby decipha » Mon Jan 07, 2019 8:24 pm
in that case PATS is prob not the issue, best to re enable it you can see if pats is working by the theft light turning off with tbe ignition on
Unread postby lowranger96 » Tue Jan 08, 2019 5:31 am
I tried last night to get it to crank with no chip in it, but the ecu still doesn't match the key, pats module, or cluster. I'm starting to think maybe the pats module or the chip in the key has died
lowranger96
Unread postby decipha » Tue Jan 08, 2019 6:38 pm
instead of thinking why not just look at the theft light it will tell u
Unread postby lowranger96 » Sun Jan 27, 2019 1:31 pm
We have it cranking, but we get a theft light code. Engine will not start, appears to be no injector pulse. Maybe I don't have everything in the ecu turned off for pats?
lowranger96
Unread postby decipha » Sun Jan 27, 2019 1:51 pm
yep, clear the code and see
theft code can also be due to weak battery
Unread postby lowranger96 » Sun Jan 27, 2019 3:02 pm
We were having a weak battery issue but I had apparently written the chip without actually turning pats off. Oops. Got pats turned off and it runs!!
lowranger96
Return to EEC-V & SN95 Tuning
