Tune review, need trans to shift higher
Unread postby lilxtra » Sat Oct 13, 2018 3:24 pm
Decipha, Just wondering if you could look over this file and let me know what it needs.
Vehicle Sheet: Filled out and sent in
Car details: This car was just bought from a dealer: 1994 Gt AUTO, the engine is mostly an UNKNOWN quantity: it has a knock off Edelbrock intake, BBK 70mm TB, Bosch 36# inj and a Pro-Flow 80mm maf calibrated for 36# injectors S/C's ( car is not), Unknown aluminum heads and cam, shorties, 3.73's, Car has an unknown shift kit!. Car idles and runs fantastic!!
Exact issues: With the mods I've done car shifts at WOT: 1-2 at around 5500, 2-3 5700, 3-4 5500, want it to shift 1-2,2-3 at 6000
Specific areas to improve on: advice on WOT shifting
Datalog: Not sure how to convert csv to zip file
lilxtra
Vehicle Information: 87 LX,stock 302,QH
Vehicle 2 Information: 94 Gt J4J1,CBAZA,QH
Re: Tune review, need trans to shift higher
Unread postby lilxtra » Wed Oct 17, 2018 6:36 am
Any idea on how to post a datalog?
lilxtra
Unread postby 034v » Wed Oct 17, 2018 7:19 am
From the looks of your BIN, none of the injectors or MAF are different. Trans shift schedule is mildly different.
You have 36# and 80mm MAF in there now?
1996 Mark VIII LSC - Turbocharged/Intercooled/Methanol, Stall, Tuned, Fuel Support, LSD, blah-blah, really fun, wins most. XDF Available
1994 Mark VIII Farm Car - N/A, Manual Air Ride, Exhaust, Tuned, Projector Retrofit, cruiser car, fun, wins way more than before. XDF Available
2009 F-150 5.4L - SCT Tuned for corn by me, pulls well.
034v
Vehicle Information: 1996 Lincoln Mark VIII, SCT and TPRT Tuning
Vehicle 2 Information: 1994 Lincoln Mark VIII, SCT and TPRT Tuned
Vehicle 3 Information: 2009 Ford F150, SCT Tuning
Unread postby 034v » Wed Oct 17, 2018 7:30 am
Looks like a stock bin..
034v
Unread postby 034v » Wed Oct 17, 2018 7:33 am
Try addressing the N/V Base and Product too.
034v
Unread postby lilxtra » Wed Oct 17, 2018 7:49 am
Car has a Pro-Flow maf calibrated for the the injectors, tune is basically stock as shown. I just wanted to find out how to get it to shift higher, car idles/drives wonderfully so no reason to make a bunch of changes, although I did make some after I sent this. A 16 yr old kid is getting this car and it has enough power as is.
What should I do to the N/V base and product?
lilxtra
Unread postby decipha » Wed Oct 17, 2018 9:18 am
details are in the trans write up
Unread postby 034v » Wed Oct 17, 2018 9:21 am
lilxtra wrote:Car has a Pro-Flow maf calibrated for the the injectors, tune is basically stock as shown. I just wanted to find out how to get it to shift higher, car idles/drives wonderfully so no reason to make a bunch of changes, although I did make some after I sent this. A 16 yr old kid is getting this car and it has enough power as is.
Well, I usually bring it up higher to carry the rpm up across the shift schedules. Example: make it 47.5 on the Base and 190 on the Product, set min/max learned to absolute. Doing so will require lowering the lower TP points. 1-2 wot shift to 1000 rpm lower than desired, 2-3 wot 3-500 lower, 3-4 right at.
034v
Unread postby 034v » Wed Oct 17, 2018 9:40 am
ODB1 has a multiplier of 4 so keep it * 4 in the change. Stock 3.27 car is around 44.5, 4.10+ 50. Ford sets them anywhere between 37-40 and has very little min/max learned range. This also has to do with tire height.
034v
Unread postby 034v » Wed Oct 17, 2018 9:42 am
The BIN you have is 37*4=148
034v
Unread postby 034v » Wed Oct 17, 2018 12:06 pm
you can also try and copy the 3-4 shift schedule into the 3rd gear lock.
034v
Unread postby lilxtra » Thu Oct 18, 2018 7:06 am
The tune **IS** almost stock, the maf is calibrated for the injectors, car runs fantastic, idles good, no issues other than it shifts to soon so I didn't put a lot of changes into the tune. A 16 yr old kid is getting this car and no sense going crazy with the tune on a car that already runs good.
THANKS for all the input guys! It IS really appreciated!
lilxtra
Return to <<--Tune Review-->>
