New 363 in a 95 GT (ecu pcm pins wedgelock)
Posted: 2021 Jul 16, 18:30
by fordman428
I am working on a few final installation details and will soon be ready to start a remote tuning session. I have just a couple questions before I start. I have a quarter horse that I luckily ordered a year ago and have downloaded the tuner pro software. I will fill in all of the specific engine details soon. I will be using a slot MAF recommended by you in a 4 inch inlet tube with a screen. I will also have the Siemens Deka 80LB injectors purchased from your recommended supplier in a stock 95 fuel rail with a factory regulator.
My car will have shorty headers and a Bassani X-pipe for now. After reading the pre-tune information I will have to use only one O2 sensor and it should be the right bank? That would leave the left side bung available for a Wideband I think.I also do not have provisions for an EGR anymore so I should be able to hook the 0-5 volt output from the Wideband to pin 27 of the 60 pin harness at the ECM.
I read that you like the 30-4110 AEM Wideband. Are the newer style X-series models also acceptable? Mainly looking at this model to match my other two gauges and be easier to see.
Do you have a good source for the harness side terminals of the 60 pin so I could remove the old pin 27 and leave it intact and just slide in a new pin and wire form the Wideband? Google searches for this were all over the map for this.
I installed a new 255 fuel pump in the stock location and am using the stock fuel lines. Is it recommended to bypass the fuel pump relay in the CCRM for this application?
Anything else I am missing?
Ken
Re: New 363 in a 95 GT
Posted: 2021 Jul 16, 20:39
passenger side is bank 1 that you'd keep.
Always best to add another bung for the wideband and keep both o2s just to verify fueling from side to side though but no biggie if you can't or if its too difficult.
yeah all the aem's are good widebands.
nope highly unlikely you'll find a new pin. If need be sacrifice a bin from a junk harness or get one from the yard.
nah you can keep the stock fuel pump relay but I usually add another relay as well if using more than 1 pump.
read over the pre tune info.
Posted: 2021 Jul 17, 17:28
by fordman428
No problem at all adding another bung. Should I keep it a certain distance or clocked differently from the factory one? I understand that I need to keep an up angle on it to help the sensor live longer.
I'm sure I have a harness around here I can sacrifice a pin from.
I have read the pre tune info several times and have a couple questions.
I have been planning on using a 180 degree thermostat on this engine,I read you recommend a 195. I know that a thermostat alone won't make the engine run cooler but I do have an upgraded radiator and water pump also. My thinking was that keeping it cooler would help with my borderline too high compression and let me run on the 92 octane I have available.
The other thing I noticed was my car has a black TFI module mounted in the heatsink. I'm pretty sure this is the original module for the car, I had a livewires "dynamod" module in it long ago but I'm sure I replaced it with the original some time ago. When I look up a factory replacement Motorcraft module for my car it also shows a black module. Am I missing something?
One last question is do I need to reference my user name here when I make my donation so you know who it's from?
Posted: 2021 Jul 17, 22:28
6" past the collector where all cylinders mix on that bank is always best
You thought wrong. Temperature has no affect on compression. Perfect temperature for most all engines is 212 degrees unless it runs methanol which perfect temp is about 230 degrees.
black oe grey module doesnt matter so long as you have the correct one set in your tune otherwise youll get misfires
yeah just put your user name in the comments no biggie
Posted: 2021 Jul 18, 02:17
by fordman428
I know that temperature will not change my compression ratio, maybe I should have worded that differently. It seems to be a common thought by many in the industry that reducing engine temperature helps with detonation resistance. I have no idea if I will have detonation problems or not but I'm pretty sure that I'm pushing the limits. Engine specs are now in my profile. If you think we can work with what I have and use a 195 stat I'm all for it. If I need to get better gas or use a quality octane booster, I will.
Ken
Posted: 2021 Jul 18, 10:23
That's what I meant too. It doesn't they are just ignorant. Detonation is too much ignition timing for the condition, nothing else has any affect on that.
I've ran 87 octane with 30lbs of boost on a 10:1 compression engine in a 6500 lb truck towing. You can make anything work.
Might as well run what you have.
Posted: 2021 Jul 23, 13:12
by j71m79
Those 60 pin connector terminals are available at Clips and Fasteners. Just go there and search wedgelock. They have both sizes.
Posted: 2021 Sep 06, 02:47
by fordman428
Thanks for the info on the pins, I have bee away for a while and haven't checked this page recently. Just pulled the ECM tonight to put the quarter horse in, seems to take me forever to find time to get things done lately.
