FN-875HN, ITHBMA not functioning
Posted: 2021 Jun 16, 20:31
I've been trying to dial in idle air by watching the datalog payload DESMAF_PID-N. I was off by about -0.35 correction.
Changing ITHBMA doesn't seem to affect anything (which I believe my ITHBMA is the actual problem. my throttle body flows 0.640 lbs/hr with the screw all the way out).
Then, tried changing the values in FN-875HN and FN-875HD across the board, which also resulted in no change.
I was finally able to dial in idle (I was able to bring the logged DESMAF_PID_N to fluctuate around 0.00) by lowering the entire FN-1862N table by quite a bit.
FN-1862N was the only table that I could get to affect idle.
This did fix my hanging idle issue!!! However its not perfect. 725 rpm idle is near perfect correction at 0.00, but if I bump it to say 1500 rpm, I'm off by about -0.11. Obviously, I can't fix this due to FN-875HN not working for me.
Sorry for the long post. Once again, FN-875HN and ITHBMA are not working for me. Could this be a definition problem, or do I have something set wrong here? BIN is attached if needed.
