dash cluster
Forum for getting assistance with mechanical issues and custom fabrications/modifications
dash cluster
Unread postby witnlyn » Wed Jan 03, 2018 8:10 pm
any information about dash cluster would be helpful. I have a gt cluster in my v6 that I swapped a 5.0 into, pats is disabled but my tach is not working. I do show rpm on tunerpro data logging though. 99 v6 to 5.0 Windsor swap with eec-v cvaf1 strat
witnlyn
Premium Member
Vehicle Information: 1999 Mustang, 5.0L transplant
Re: dash cluster
Unread postby motorhead1991 » Thu Jan 04, 2018 4:06 am
Take a look at the wiring going to the cluster. When I built the adapter harness for my OBD2 conversion, I pinned the wrong wire. That might be the case here.
motorhead1991
Re: dash cluster
Unread postby witnlyn » Thu Jan 04, 2018 4:23 pm
ran diagnostic test on it and needle doesn't sweep so going to test original cluster to verify wiring not the issue
witnlyn
Premium Member
Re: dash cluster
Unread postby witnlyn » Thu Jan 04, 2018 6:38 pm
problem solved white face was touching needle. The simplest thing can be such a headache.
witnlyn
Premium Member
Return to Mechanics & Fabrication
