CABHO Def needed
comptuner
Vehicle Information: 90 Supercoupe, 2nd owner
00 F150 4x4, 2nd owner
93 Towncar, from a little old lady, really
89 GT convertible
CABHO Def needed
Unread post by comptuner »
I've done a 4r70 swap in a 93 Towncar and need to correct the gear ratios.
Currently using a CZAJL strategy on the J3 and it works good but now the canister purge valve doesn't work and I don't like smelling gas fumes.
I pulled the original strategy which is CABHO, which is probably the same as the sought after EDIS A4A1 code. Need an XDF for one or the other, or perhaps an XDF for the CZAJL that has access to the canister purge scalar as it appears to be either disabled or some other issue.
Any help or direction would be greatly appreciated.
Re: CABHO Def needed
what is the original cal code?
Can you post your file.
comptuner
89 GT convertible
Code is J3D1
93QH_read.bin
(56 KiB) Downloaded 709 times
034v
Unread post by 034v »
I have a full CZAJL xdf.
CZAJL would take some work as you'd have to dial everything in.
Give this a go.
93QH_read_4r70w_swap.bin
(56 KiB) Downloaded 659 times
comptuner
89 GT convertible
Ok, Thank's I will try it tomorrow
Greatly appreciated.
comptuner
89 GT convertible
Thank you Michael, that worked great. Is there an actual def for that file? I need to add a little pressure on the 1-2 shift because of the bigger ratio spread.
pressure is how hard it shifts not when it shifts
are you saying its shifting too early which is shift schedule
or is it shifting on time but taking too long to complete the shift ?
comptuner
89 GT convertible
Too long to complete the shift the timing is fine
Thank's
enjoy
93QH_read_2.bin
(56 KiB) Downloaded 593 times
