Dialing in FN1861
Posted: 2021 Jun 11, 11:35
by m-barans
Am I correct in assuming that the way to dial FN1861 in (after t-body adjustment is corrected which is done) is to log a start-up, view the log while monitoring (ATMR3, DESMAF and ECT), deduce what cell we are in in FN1861 at a time/place in log and add/subtract DESMAF correction value from said cell? I’m just trying to clarify this process for my conceptual understanding so I can quit chasing my tail and make some actual progress. Thanks
Re: Dialing in FN1861
Posted: 2021 Jun 11, 14:30
yep that's it
atmr is at the top right of the dash
simple add or subtract the cell in use to try to get the idle air error to 0
Posted: 2021 Jun 11, 15:15
by m-barans
Neat! So, I need to repeat this in Drive, correct? Also, it seems implied that the start up IAC duty cycle would likely need to be dialed back since our t-body has been adjusted to be open more at all times. I lowered start up crank duty cycle a bit and crank pw similarly and start ups tend to be less dramatic now too. Should I move on to dash pot and the A/C adder after finishing up with the ISC D and N multipliers?
Posted: 2021 Jun 11, 17:52
yep
btw I posted my tune from my marauder along with updated adx and xdf files
Posted: 2021 Jun 11, 19:12
by m-barans
Thanks for sharing that and those updates. I really feel like I'm raping the ISC multipliers because the tables are beginning to look a little ugly lol. Is that ok as long as the DESMAF gets close to 0?
Posted: 2021 Jul 07, 11:26
yep
