help with timing
specific forum for all Holley EFI tuning support
Holley Software
help with timing
Unread postby g3mustang » Fri Jul 14, 2017 1:24 pm
holly hp 427 11.1c 220 afr heads e85. was having a horrible time with breaking up issues and blowing up pistons. We lowered and raised timing, added fuel and decrease fuel nothing helped. thought it was jumping spark from the Fast distributor. So ive gone coil on plug. wanted to break in the motor by cruising it around. did a couple quick wot pulls and some half throttle stuff. well I blew a head gasket! I feel like it was maybe due to to much timing under light load. zero vac and zero boost is 31 degrees. so half throttle and no boost is little bit more timing. Please help.
g3mustang
Supporting Member
Vehicle Information: 393 s475 b/w turbo 9:1 compresion 185 afr heads c4 trans a9l2 tunning with BE e85
331 180 heads, cobra intake, 50lb injec., cobra maf, anderson cam
Re: help with timing
Unread postby SlowBox » Fri Jul 14, 2017 1:37 pm
Gotta be too lean. You should be .80 lambda and getting richer at 0 vac/0 boost. The plugs will tell the rest of the story.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby g3mustang » Fri Jul 14, 2017 1:43 pm
plugs all look good. and doesnt 11.8afr seem a little rich at half throttle?
g3mustang
Supporting Member
Unread postby SlowBox » Fri Jul 14, 2017 2:12 pm
11.8 AFR is so lean I doubt it would even light off. If you're melting pistons and popping headgaskets, the plugs will show it. There is a problem.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby g3mustang » Fri Jul 14, 2017 2:19 pm
11.8 afr gas scale is lean?
g3mustang
Supporting Member
Unread postby SlowBox » Fri Jul 14, 2017 2:26 pm
You said the car was on E85 in your OP. If the car is breaking up, that right there is telling you it's dangerously lean. Part throttle is irrelevant here because the motor isn't gonna make enough power to hurt itself.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby g3mustang » Fri Jul 14, 2017 2:28 pm
i am on e85 just use gas scale in holley
g3mustang
Supporting Member
Unread postby g3mustang » Fri Jul 14, 2017 2:32 pm
When at wot i commanded any where from 10.5-11.8 nothing changed
g3mustang
Supporting Member
Unread postby decipha » Fri Jul 14, 2017 3:05 pm
on e85 for max power you should be commanding .68 lambda
14.7 * .68 = 9.99 AFR at WOT
that doesn't sound like a bunch of timing, make sure the heads and deck are machined true
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Return to Holley EFI
