Histogram usage
Posted: 2021 May 25, 14:16
So im not sure if i am using the histograms right. Normally, i select the applicable histogram and choose running average for the filter but im starting to question if u am choosing rhe best filter/view. I feel like when dialing in fuel i would probably be better off filtering using the history average since it takes the last 10 rolling samples. Since hist_FuelErr is basically just showing ltft the most recent average would probably be closer to current ltft than say and average of 6000 or more samples right? When i dial in fuel i just take it for a long drive and watch the samples count by cell and fluctuate the speed, throttle and gear to target individual cells so i tend to get a large sample base before making changes again
Have you ever thought about doing a wire up for the histograms? I know i would benefit from it.
