Page 2 of 3
Re: Luxury ECU wiring questions
Posted: 2021 May 20, 22:29
your not gonna use any of those
yep u can add a knock sensor
aod is probably a hall but u can wire it up to the oss and we can see if it works
Posted: 2021 May 21, 13:33
by 91GTman
Are you running all ground pins # 3,24,25,51,76 and 103 to a single point on the chassis?
Posted: 2021 May 21, 15:18
yep dont forget 77
Posted: 2021 May 21, 20:46
by dleach1407
91GTman wrote: ↑2021 May 21, 13:33
Yeah, all grounds will be combined and go to a chassis ground.
Posted: 2021 May 26, 13:10
by dleach1407
Any problems with eliminating the downstream Hegos? Hego 12/22. Also, my ECU harness does not have pin 77 as an open connection, its capped off. I got the ecu and harness from the same Crown Vic.
Posted: 2021 May 26, 13:51
nope just use what you need
Posted: 2021 Jun 05, 15:24
by dleach1407
decipha wrote: ↑2021 May 20, 22:29
Should I run the wiring for OSS and VSS incase I need to change it around or should I not worry about it and just repin it at the ecu if needed? I assume both of them use signal return?
Posted: 2021 Jun 05, 15:31
just swap it at the ecu
yep
Posted: 2021 Jun 06, 00:00
by dleach1407
pin 29 TCS=Overdrive switch? Not sure I need an overdrive switch
Posted: 2021 Jun 06, 09:15
nope
