Ford Idle Air adjustment spacer for surging idle
I was curios if any one has used the FORD part# F2PZ-9F939-A Idle Air Adjust Spacer to solve idle surging issues?
Does it work for SD?
Or does it even matter if you are tuning?
Re: Ford Idle Air adjustment spacer for surging idle
Its absolutely useless you just simply set your throttle stop correctly.
