Individual cylinder timing
Posted: 2021 May 04, 12:59
by VJordan
Is it possible to do individual cylinder timing on cvaf1 ? At least for cylinders 7&8 on a 4.6 . If so what scalar would it be?
Re: Individual cylinder timing
Posted: 2021 May 04, 13:21
SPKAD_CYL9 is cylinder 8 and SPKAD_CYL8 is cylinder 7.
Posted: 2021 May 05, 08:54
by VJordan
I checked those and somehow cyl9 was -3 and cyl8 was -0.25
So I made cyl8 -3 also and it just backfires like crazy out the exhaust if I put it back to -0.25 it’s fine
Posted: 2021 May 05, 09:10
sounds like your using the wrong bin file
Posted: 2021 May 05, 10:07
by VJordan
It’s the same bin I’ve been running for the past year or so ,
I tried the newest one you posted but the car wouldn’t stay running and I didn’t have the time to find why so I switched back to the bin it’s been on
Posted: 2021 May 11, 08:05
You learn nothing if you don't figure out why something doesn't work when it should.
Posted: 2021 May 22, 19:03
by VJordan
I’m going to try it again and see why it wouldn’t run I just didn’t have the time at that moment that’s why I switched back
Is it possible for the fuel pump to be getting maxed even the duty cycle says .43 which is about 86 percent ? I can’t get the fuel pressure to follow 40 I’ve played with the pids , I halved them at first but I don’t really know what to do with them just been trying different settings . When rolling into the throttle fuel pressure shoots up then drops to about mid 20s the afr stays fine though because of the compensation so I haven’t worried about it too much but would rather not have the pressure so low
Posted: 2021 May 22, 21:00
the fuel pressure histogram shows you exactly what it needs to be
just simply take the corrections tunerpro gives you and apply them
fuel pres sure be solid as a rock then
