crai8 loads dropped 24%
Posted: 2021 Apr 29, 13:47
by redtopracer
Like the title says, load dropped almost 25% across the board with the new bin. Previous peak was 94% now its 70 and im not sure why lol.
Maf still shows same peak flow, so i doubt im loosing a cylinder.
Re: crai8 loads dropped 24%
Posted: 2021 Apr 29, 14:23
your old tune scaling was off
if you reduce the engine size then load will come up
Posted: 2021 Apr 29, 14:38
by redtopracer
Well don't I feel extra special now lol. Thanks
Posted: 2021 Apr 29, 17:19
by redtopracer
Not having any issues other than the same I was with the scaling for the SP* that I was with craj0 bin. What am I doing wrong in following your instructions on them? The scalar still throws the whole thing off, and if i change the scalar to 1 it of course moves the fuel settings. changing the fuel settings results the scalar doing its auto thing again.
Posted: 2021 Apr 29, 17:31
why are you changing them ??? do they not already have accurate values ??
Posted: 2021 Apr 29, 17:33
by redtopracer
None of its done like you say it should be. Is there a benefit to having the global k constant to 30 and all that?
edit,fuels scaled correctly, wideband reads same as commanded. but global k constant isnt done like you say. to clarify
