Page 1 of 2
RZASA adx?
Posted: 2021 Apr 17, 23:33
by dleach1407
Does the RZASA need an ADX file? I don't see it listed in the downloads section.
Re: RZASA adx?
Posted: 2021 Apr 18, 18:44
by ConWasabi
<edited>
Standardized adx can be used from any other decipha adx but you have to manually select the strategy your using it on.
Re: RZASA adx?
Posted: 2021 Apr 18, 19:44
All of the adx files are the same just the strategy isnt selected if you need to swap strats.
Best to just hold off til I post one with rzasa selected when i get a free moment.
Re: RZASA adx?
Posted: 2021 Apr 18, 22:18
by dleach1407
Thanks. I started building my truck and will to need to build a base tune to get it started. Got the 21 circuit harness installed this weekend and Ill be starting the engine harness this week.
Re: RZASA adx?
Posted: 2021 Apr 19, 14:37
its posted
Re: RZASA adx?
Posted: 2021 Apr 19, 22:39
by dleach1407
Thanks Mike!
Re: RZASA adx?
Posted: 2021 Apr 19, 23:02
by dleach1407
Is there a write up for the RZASA minimum changes for needed like there is for CBAZA?
Edit: I think i found it under eec-v strategy swap
Re: RZASA adx?
Posted: 2021 Apr 19, 23:14
its not up to date but should get you going
http://efidynotuning.com/eecv.htm
Re: RZASA adx?
Posted: 2021 Apr 19, 23:47
by dleach1407
So I am running into my first problem. the continental data does not have any of the deltaP data that is required for the injector data. Is there a way to calculate the information? The injector data I have is for 43.5psi
Re: RZASA adx?
Posted: 2021 Apr 20, 07:34
only way to calculate it is to dial it in. But your not running a returnless fuel system so you don't need it.
