[J1X] 4.9L Stock Tune/Strategy
Posted: 2021 Apr 14, 17:52
by efloth
I posted this over at the https://fordsix.com/threads/stock-ecu-tuning.82060/ today. Useful for anyone with a 4.9 and manual trans or for adapting A1C for the 4.9l and auto trans
Re: 4.9L Stock Tune
Posted: 2021 Jun 16, 18:37
by efloth
Ported Decipha's patch for extended VE table
Re: 4.9L Stock Tune
Posted: 2021 Jul 20, 20:11
by efloth
Updated ADX, still a few broken items
DECIPHA_210620_J1X.adx
(384.64 KiB) Downloaded 1816 times
Re: [J1X] 4.9L Stock Tune/Strategy
Posted: 2023 Mar 27, 13:17
fn703f different y axis equation /128 (iirc) and only 10 points as well
Posted: 2024 May 22, 19:56
by fofaster
Been working with efloth over on fordsix forums, I wanted to bring this over here and post the latest updates to this strategy. My motor setup has all the emissions removed, if you are using this and have emissions equipment installed you probably need to re-enable those flags. Still working on a completely dialed in VE Table but this should be a good place to start for anyone that wants to use this strategy. You probably need to turn down the A/C fan load in this, I keep forgetting tbh.
I am green tuner and my strategy could harm your vehicle unintentionally. DO NOT INSTALL FOR DAILY DRIVING (still developing this into a more stable tune with a truck that I can afford to blowup) you do download this and make it better PLEASE repost your strategy
UPDATED 6/22/2024 Fuel is a lot more dialed in and this strategy seems to be running A LOT smoother than before. If you've downloaded this before, you might consider redownloading this update. Still working on start up idle, might need to retune the idle air again. This is again for a stock motor with emissions deleted, 3* of spark added across the board, extended VE. Make sure your timing is set mechanically to 10*
Posted: 2024 May 28, 23:40
by 73Torino351C2V
I have an e4od. Where is the correct down load for efi-sd47a?
Posted: 2025 Sep 10, 21:01
by GeneratorGene
Still happy with this tune? Looks like exactly what I need to get started with my build, thanks!
