We all know it (Tremec) has a OSS magnetic sensor and the SFI-SD3 uses a VSS (no cable in this application) that looks for 8,000 PPM.
My XDF accesses the PPM scalar and it's indeed 8,000.
I'm guessing that changing this scalar will do jack for speedo correction.
So most likely a Dakota Digital SGI-100BT will suffice?
**V6 T5 for those thinking it's a modular trans..**
2001 Tremec T5 in place of AOD
034v
Re: 2001 Tremec T5 in place of AOD
Can't you change the tail shaft to the older one?
034v
Yes, easier to get the speed calibrator tho. Sourcing the T5 was hard enough.
