TALD5 vs MZAK0 strategies
Posted: 2026 Nov 08, 18:29
by StoichPerformance
I was curious what the differences are between the two? I've been running the MZAK0 strategy on my 2000 v10 excursion with no issues for a couple of years, but would like a couple more things to adjust. namely specific gear commands(1-2/2-3/3-4 all separate) and the in gear idle RPM(for AC in traffic). I have neutral control but nothing for in gear. I also cannot get light throttle/load timing as high as I want and cant find a scalar, function or table clipping the borderline knock
does the TALD5 have more or different things to tune vs the MZAK0? what are the most notable differences in your opinions?
Re: TALD5 vs MZAK0 strategies
Posted: 2026 Nov 08, 19:58
None, they are the same. TALD5 is just a newer compatible strategy.
post your current tune file and I'll take a look
Posted: 2026 Nov 09, 19:01
Will do, thanks. I'm not seeing a way to add attachments, so as soon as I figure that out, I'll get it posted
Posted: 2026 Nov 11, 19:35
here you go. you'll notice a massive valley in the spark table. I have to have it for lockup and OD. I also have PI heads on an NPI rotating assembly
Posted: 2026 Nov 14, 21:44
by gpickering68
Had exactly that valley on my old Defender when I bolted some bigger injectors on and never retuned proper, converter lockup used to shudder like it was coming apart. Ended up just living with a dip through the lockup/OD cells cos chasing it flat caused pinging on part throttle, so dont worry too much, PI heads on NPI block will always want a bit of a compromise there. Worth keeping an eye on EGTs in that range though, mine ran a fair bit hotter than id have liked before I sorted the converter itself.
Posted: 2026 Nov 15, 10:22
I have stock injectors. I could eliminate the valley if I could delay OD or lockup. sub 1600rpm in lockup/OD is a bit low for these engines and their torque curve anyways. I've tried playing with the NVBASE-RPM/VSBAR ratio. but it delays the 1-2 way too much. So much so that on a WOT pull into traffic it'll bounce the rev-limiter right before/as it makes the 1-2 shift. which I feel is way too high for a basically stock heads, cams, and intake engine.
Posted: 2026 Nov 15, 15:23
if you have the original 2000 excursion ecu its most likely a 3.0 clock ecu, XTALHPS needs to be set to 3 instead of 4 to calculate everything correctly.
Why would you raised nvbase instead of lowering it?
spark is being clipped by max spark and mbt, I raised both for you.
I see you adjusted some knock sensor values, the knock sensor is disabled.
Attached updated MZAK0 xdf to the mzak0 thread with the tcc lock/unlock and shift schedules as well as dnac.
Modified your bin with xtalhps and a few others that need to be done.
I've also attached a tald5 converted file from xyb0/mxh0/2/3/4. If you can try running it as is and let me know how it responds. I'm curious to know.
Posted: 2026 Nov 15, 20:52
Thank you! You are a godsend to the community. i will try to make time to play with those some later this week.
Posted: 2026 Nov 15, 21:05
The clock speed I changed back to 3 a couple times before. something in my old laptop kept switching that. but I now have new laptop with a fresh TunerPro install it shouldn't be a problem.
As for the NVBASE. I had a day that I went to make some small changes and it quit making any change. So I made a big jump up and it did nothing. I left it alone and forgot about it because I got in a wreck later that day. Shortly after the trucks battery went bad (I suspect its the reason I saw no changes). the shifts never changed with the fresh battery, never giving me cause to go back and check it.
Posted: 2026 Nov 18, 19:00
by GPetts62
Evening all. Reminds me of when I had a dodgy relay on the lawnmower years back, kept thinking I'd knackered the carb settings when really it was just the battery dying underneath me the whole time, spent a weekend chasing ghosts that weren't even there. Bloody hell, batteries are sneaky like that, they go just enough to mess with everything downstream but not enough to stop it starting, so you never suspect it till something else fails and you look back. Defo worth checking that stuff again now the new battery's in rather than assuming the old test was valid, could be the NVBASE jump actually did summat and you just never saw it properly. Anyway not my area really, excursions and these spark tables are a bit beyond me, just thought that battery gremlin story was too familiar not to mention 😂
