Tunerpro RT Update - Oct 14, 2026
Posted: 2026 Oct 25, 08:57
Few bug fixes mostly with table editing.
Anywho, new download available.
https://www.tunerpro.net/download/Setup ... _10335.exe
Re: Tunerpro RT Update - Oct 14, 2026
Posted: 2026 Nov 01, 17:17
by DougW
Cannot load CBAZA xdf file in version 6. Error is UT-8 encoding.
Any ideas?
Doug
Posted: 2026 Nov 01, 17:46
use the v5 version for now, ill let mark know
Posted: 2026 Nov 02, 09:21
Updated version posted that fixed it
https://www.tunerpro.net/download/Setup ... _0_422.exe
Also tunerpro.net had a facelift too
Posted: 2026 Nov 03, 14:38
by DougW
Thank you for the quick update. In three instances using the dashboard, there appears to be a memory leak. Program crashes randomly.
While on the dashboard subject, is there any way to operate as a separate window as before? I don’t see a maximize or minimize on the window border now.
Doug
Posted: 2026 Nov 03, 20:36
damn well need more work then
can you go in to more detail with the program crashes and what your doing exactly?
Posted: 2026 Nov 04, 10:40
by DougW
I was editing a bin. Program was not connected to Quarterhorse or getting data. Opened up the dashboard to adjust the size and familiarize myself with the new version 6. Several times the program would simply crash to closed. No error messages received. I would have to start the program again. I think it happened once when connected to Quarterhorse and acquiring data.
Not sure if that helps, but it is all I’ve got.
Doug
