Linking Wideband O2 sensor to A9L ECM
Posted: 2026 Aug 04, 18:06
by zcodeboyz
I have an Innovate MTX-L wideband O2 sensor That I'm trying to get linked up to my A9L ECM using Tuner Pro RT and a Moates Quarterhorse. I'm trying to use the Pin #27 voltage input method. The gauge is outputting 2.75 to 2.78 volts at 1.00 to 1.02 lambda at the old EGR voltage input circuit. I have continuity all the way to The ECM at The pin 27 location. I cannot get the Tuner Pro RT ADX file to recognize the signal. The settings on the General and Conversion tabs appears to be correct. The 8 other values on my dashboard are all active and working. Any help on getting this issue resolved?
Re: Linking Wideband O2 sensor to A9L ECM
Posted: 2026 Aug 11, 16:15
by zcodeboyz
Between my two AI Bud's, CGPT and Super Grok, We figured it out. Issue resolved.
Posted: 2026 Aug 12, 09:34
There is no setup its all automatically done.
If its not logging then a wire was not making a connection.
Posted: 2026 Sep 02, 17:22
by AmberFox92
good to know, wiring issues always end up being the culprit on these
Posted: 2026 Sep 02, 17:23
by AmberFox92
good to know, wiring issues always end up being the culprit on these foxbody setups. always double check grounds and pinouts before chasing tune settings
