TFI modules
Posted: 2026 Jul 20, 11:56
by red5.0fogger
Hi, Which TFI modules can be trusted these days? I think there are some fake motorcraft out there now?
Is there a certain store or supplier that is known to be trusted?
Re: TFI modules
Posted: 2026 Jul 24, 06:41
by red5.0fogger
I'm trying to get the last little bit out of it.
This combo should be making nice power into the 6000rpm range. For a while I've noticed it lays down at 5500rpm. Not suddenly and not breaking up, just lazy after 5500.
I put in a new motorcraft tfi module on a hunch as something i may have overlooked.
took it out for little rip and it was quite promising from what I can tell. sounds and feels stronger above 5500rpm.
Re: TFI modules
Posted: 2026 Jul 28, 16:27
by efloth
Stick a 4700uf capacitor between the positive and negative terminals on the main TFI connector. Depending on the noise levels in your electrical system you should notice a nice improvement. I had to run only motorcraft modules until I made this simple change. Others were breaking up as RPMs climbed.
