2017 Ford escape code history
olddog
Vehicle Information: Replica of 1967 AC Shelby 427 Cobra built 2001
Engine is 302 bored & stroked to 347
Mass Flow EFI set up. Designed to look like a 1960"s carb. Air filter on top of a 1000 cfm throttle body that resembles 4 barrel carb. MAF inside air cleaner. I have removed air filter & MAF. Put a "Hat" on and extended pipe. Put a PMAX HPX mass flow meter in the pipe. 36 lb/hr injectors. Fuel Return with regulator.
ECU-IV A9L
Edelbrock Performer heads
Edelbrock single plain Victor Jr intake with drilled and welded port injection
Comp cam 35-000-8 hydraulic roller
intake 0.550 lift duration @0.006 = 287 Opens 12 BTDC Close 44 ABDC
exhaust 0.576 lift duration @0.006 = 293 Opens 55 BBDC Close 7 ATDC
Unread post by olddog »
It is my understanding that there is a error code history that keeps a record, after the code has been cleared. I you disconnect the battery for a few days, will the history clear?
Re: 2017 Ford escape code history
Your referring to freeze frame data.
Yes, you can also do a pcm reset.
