2001 Escape 3.0 4V
Posted: 2026 Jun 14, 17:11
I'm trying to help my brother with his "economy" Ford now that the increase in gasoline prices are costing a lot using his 5.0 Explorer daily.
He has been chasing down a misfire and has even sent the pcm off to a repair business to repair the pcm. Originally missing on #1 cyl and #2.
Late Friday he had it down to just #1 with the repaired pcm. He purchased a JY pcm and the owner said if it didn't work, send it back for a swap.
I used my Scanmatic Pro 2 along with Oleg's PcmFlash module #29 software. I flashed or wrote to it an identical bin file from his original pcm. I assumed that after installation, the Escape would fire right up. Nope! nor with a 2nd replacement. Am I overlooking something? I'm not familiar with these Escapes. I haven't had any problems making "clone" pcms for our 1998 and 1999 Explorers. Also, no problems with PATS off versions. I haven't had to do the grounding the dk blue/or stripe wire that I had to do with my 1999 Ranger 3.0 truck.
During all of this, this #1 misfire has been fixed. Brother went into the harness near the 104-pin connector after detecting on "open" short. Someone's repair pulled apart on the #1 coil circuit. Truck runs great now with the repaired original pcm. He just wants a spare pcm to carry with him on his commute that is off of the beaten path, so to speak.
Should a pcm work that I do have a PATS off program that my PATS off friend, Pat in IL fixed up for me?
Would it be plug and play or would a PATS module wire need grounded? I'm not finding anything about PATS modules in 2001 Escapes.
Thanks in advance for any insight guys!
