Datalogging Patch will not apply
Posted: 2026 May 24, 16:22
by Turbo4V
Tried to re-enable the datalogging patch on a binary that was previously running on an F3 chip which had the datalogging patch removed. After updating the binary with the tune changes to use with the QH, I attempted to enable the patch but get the "Patch Aborted. Base Data Does Not Match". The binary loads fine onto the QH and runs but the logging is only partially functional as expected. Using the latest ADX and XDF from the downloads page, and latest TPRT build 5.00.10305.00 Not sure why this is happening.
TURBO4V_Working.bin
(256 KiB) Downloaded 643 times
Re: Datalogging Patch will not apply
Posted: 2026 May 24, 18:54
remove the patch then add it
Posted: 2026 May 24, 19:35
by Turbo4V
The 'Disable Datalogging' patch is showing enabled, and the 'Remove Patch' button is grayed out. Is there another method to remove the patch?
Posted: 2026 May 24, 20:34
I see. Attached with logging enabled. I'll remove the remove from the patch so its not a problem for others.
Thanks for that.
Posted: 2026 May 24, 20:44
by Turbo4V
Thank you, appreciate the help.
